I am installing 2 85 watt solar panels with a charge controller wired directly to the house battery bank on my O'Day 31. The kit I purchased came with 1 inline fuse holder (30 amp) and a diagram showing the inline fuse between the controller and the battery. Is it also necessary to have a fuse between the PV's and the controller? Also, is it necessary to have a manual shut-off switch to disconnect the panels when the engine charging circuit is active or when the 3 stage battery charger is operational?
