B;ess that solar panel
Jay,      During my first season, I lugged my battery home for recharging, generally after discovering that I did not have electrial power when I wanted it.   I invested in an inexpensive 5w panel, and have never suffered that problem since.        That panel has gotten old and stepped on (its rigid construction) and I will probably replace it this summer, with a flexible panel in the 5w -10w range.   Flexible for durability.  Possible increase in wattage to speed up the recharge rate.         Issues I was told to be aware of include over-charging your battery - which is flat impossible with the low wattage I've got, but possible if you get up to 18w or more.  Therefore, ask yourself, "am I going to be checking on this often enough to avoid problems?"   You should be sure to install a diode to prevent discharge of the battery through the panel at night.   Secure it against theft, some people are less than honest.        I've seen some essentially permanent installations, but I put a stee; cable on mine which I run through  the hatch hasp when I lock up.  Won't stop anyone with good wire-cutters, but it slows down the would-be opprotunist, and lets me stow it when we're on board.          I was given and will pass on  a good suggestion on installation: cut a short  3-prong extension cord  and connect  the wires on  female end to your battery.    Then connect the wires on the male end to you solar panel wires.  Make sure that polarity is correct all the way from the solar panel to the battery.  Now, to  connect your panel, just plug in the extension plugs, or unplug to disconnect..  Using 3-prong ensures that it will always be the correct polarity  This allows us to stow the panel out of the way when we're using the boat.       I ran mine from the battery up next to the electrical panel.  The rest of the length is on the panel wires, giving flexibility in placing the panel.   When I lock up the boat, I connect the panel, put it on top of the slider and lock it with the hatch.        Live without a solar panel?  Not on your life.       Jim Kolstoe
