solar panel and battery
131
Hunter 23 WIll be at a Navy base
I have a solar panel from a previous boat. It is only about 6 inches square. Does anyone have any idea how I could get a watt reading on it. My plan was to put battery clamps on the wires and just clamp it to the battery. I was going to put a switch of the positive side so when I was not using it I would shut it off. I have looked at a 5 watt panel and I guess a regulator. When I bought the boat it has a starting marine battery and not a deep cycle. I am not sure how old. It was fine the beginning of the summer but is dead now. I brought it home and was going to trickle charge it for a couple days, then put it back and try this small panel. I have a camper with a 15 watt panel and it runs the starting of the refrig, alarms, and other things that can not be turned off. It maintains the battery for a week with no problem. I do not need anything that big as all I am running is the VHF radio and a light every once in awhile. Any idea were to get a 5 watt panel and regulator cheap. Also, what advantage is there to a gel battery. I have looked and they seem to be pretty pricey.
Jun 6, 2006
6,990
Solar power on boats
Your wattage can be calculated if you know both volts and amps at any one time by Watts = Volts*Amps. That would be panel output not something else. Do it with a more than 25% discharged battery.
With that said, your 6" square panel is not going to need a regulator as it will only provide a trickle charge at best. You just need a switch (and fuse) in the circuit to be able to turn it off at night. Some will say you need a diode to save you the trouble of turning it off at night but they suck out a volt or more of your output. With such a small panel you need every volt and watt you can get.
