Tom Wootton
I have a Unisolar panel rated at 1.96 amps and a combination cranking/deep cycle flooded battery rated at 110 Amp-Hours. I've read that no regulator is required if the panel is 2% or less than the AH capacity of the battery bank, but some sources put the percentage as low as 1/2%. I'm finding that I have to add water every week. A regulator costs about $70, and the one in West Marine has some LED's to monitor performance, charge state, etc. Does anyone have any experience with solar panel regulators? My other option would be to put the $70 toward an additional battery and parallel it with the existing battery, increasing the total AH capacity to the more conservative percentage. I see no need to seperate the batteries, since the outboard can be pull-started if the batteries are flat. Any thoughts?
