C
Chuck
Hi Folks,I'm interested in adding a solar panel trickle charge system to my H23. I've looked at the archives and see that I can do this with a diode and if the max wattage is less than a tenth of the battery capacity (I think). This boat is left unattended for up to 2-3 weeks at a time so the issue I'm concerned about is outgassing while charging. I was on the boat and looked for a possible way to ventilate the lazerette locker where the battery is stored and it's very difficult. My question is if I use a small enough trickle, should I be concerned about ventalation? (There is always some ventalation because this locker is not airtight and I'm sure there is air flow)Thanks,Chuck,SV WindsongsH23
