I am in need of finding a location for a solar charger on the 28.5.I have one of those 2w Sensei(or something like that)units and place it inside the southern exposure window over the stove. It worked fine all winter... but its not quite enough as my bilge pumps tends to draw and don't have just enough kick (sometimes) to turnover the iron jenny.So I bought a larger 5w panel from Harbor Freight($50+/-) - but its tough to fit internally. One possibility was to use "s" hooks and straps to hang it under the forward hatch-by drilling a hole in hatch's underside cross meners..... but it isn't angled to a southern exposure enough as one might like. Then I thought to mount it unto 2 upside down "j" brackets( like the ones with a hook sold to hang over a door) and have it hang on the outside over the companionway cover(Eastern exposure)where there's some opening between the lexan slide cover and the top board. It will get direct morning light and be less visible to theft from the dock on the bowside....but its not a real expensive item - and it will keep up with the periodic bilge draw and.... (hopefully) then some. The transome doesn't have enough space between boat name and the ladder wrung at the cockpit gunnal.And I bet its a matter of time before someone kicks it. A dock neighbor suggested mounting it to the "V" on the aft spreaders...... but the out "haulup" line is bound to tangle sooner or later if I'm not very careful.Any other thoughts?
