Solar Charge Controller Question
Sep 17, 2018
2
Catalina 30 San Diego
The background information: We have a Catalina 30 Mk I and recently converted it to an electric drive (love it, wish we had done it sooner). The 10 Kw drive requires a 48 v battery bank (4 group 31 AGM 105 Ah batteries) for that purpose. The house power requirements are provided by a 12 Volt battery bank (two GC2 190 Ah 6 Volt batteries). The boats previous owner installed a 350 watt solar array (two 175 Watt 12 Volt Flexible Monocrystalline Solar Panels) with a Blue Sea Systems 12 Volt solar charge controller (also handles the output from our wind turbine) connected to the 12 Volt house bank.
The main question: Recently found out that Renogy makes a 36V/48V Rover Boost 10A MPPT Solar Charge Controller. Is it possible to place a selector switch (A-Off-B) on the output cable from the panels and be able to select which solar charge controller processes the energy?
DArcy
Feb 11, 2017
1,773
Islander Freeport 36 Ottawa
You might be better off getting a 12V to 48V DC to DC charger
Or you may be able to find a 48V to 12V DC to DC charger then charge the 48V bank with solar.
Sep 17, 2018
2
I have considered that solution, but it seems that compared to charging from the charge controller, charging DC to DC would be too inefficient. Additionally, the possibility of a second solar charge controller is less expensive ($169 compared to $449). I'm still leaning toward the two charge controller option, but am open to DC to DC charger as a plan B. Thanks for the input.
:beer:
Very cool. I would love to see a write up on what you did.
Bob J.
Apr 14, 2009
775
Sabre 28 NH
I also have an electric sailboat, majority of boost controllers will not fullfill your needs. IMHO best thing you can do is upgrade your panels to a higher voltage, at least 24V. I connected the solar controller outlet to a transfer switch that is connected to each battery bank. I can pick & choose which bank to charge by simply changing the charging parameters of the controller.
DArcy
Feb 11, 2017
1,773
I understand cost constraints. I would bet any loss in efficiency from the DC to DC converter would be less than manually switching banks.
Apr 22, 2011
954
Hunter 27 Pecan Grove, Oriental, NC
I agree with what DArcy said. I think you will find it difficult to manually switch from bank to bank at the optimum time to avoid the solar controller reducing its output. With a B to B charger both banks can be topped off without any wasted solar energy.
May 7, 2012
1,571
Hunter e33 Maple Bay, BC
I’m not saying that Renogy manufactures top of the line products but give me a break Trustpilot. It seems that only folks that provide reviews to their website are those with negative experiences. Here is a short list of ratings for some well known companies:
B&G: 4.2
Victron Energy: 3.1
Raymarine: 3.1
Subura: 2.7
Tesla Motors: 2.2
Honda: 2.1
Cuisinart: 2.0
Renogy: 1.9
Sun Power: 1.9
Garmin: 1.7
General Motors: 1.3
Lenovo: 1.3
Dec 28, 2015
1,919
How big is your propulsion bank? If I'm reading it right you would like to charge it off of two 175-watt panels? Seems like the return on the work/expense wouldn't justify the means assuming the bank is large enough for propulsion.
