Jerry Woznicki
Soggy Cockpit Floor, I just purchased a 1986, 31' Hunter. After a few days, I have noticed the cockpit floor is a little soft in spots. A fiberglass repair shop says the core in the floor must be repaired and several areas of the core on the top of the cabin are wet and must be replaced for over $18,000!!!! His explination is the the former owner did not re-caulk the deck hardware and below the mast. Is there some other method of injecting resin into the "wet" areas other then tearing off the top skin and replacing the wood core?? There must be a water based resin for this!!! Someone please advise.
