Soft Scrub is made for gelcoat!
Softscrub is made for cleaning fiberglas tubs and showers which are the same gelcoat as a boat! It actually takes out the small imperfections that arise in the gelcoat. The key to keeping a boat clean is to have a good thick and slick coat of wax, then the bird and spider droppings can be mostly washed off with a hose under a little pressure. If you have a hull with no wax, the mildew and grime gets caught in the small "potholes" in the gelcoat and is then really hard to get off. I use soft scrub in the spring, then wax. Parts of my hull need it again now, but it has been so hot, I'm waiting for a few weeks to do it again. Two to three times a year will keep your topsides looking great in my region.
