Drydock dorothy
Have used "soft" anti-foul paint on fiberglass covered iron keel. Was told this year to use co-polymer Plus paint to keep down sludge build-up. This involes sanding, using a bond primer paint, then at least 2 coats of CCP paint. Should I buckle down and complete thses stages for a reward bigger than using the cheaper "soft" paint?Also, one of the paddles of the spedometer wheel under the hull is broken. Do I remove the entire housing from the hole or can paddle be replaced with super glue?Cam removable electronic devices (depth gauge) be checked at boat stores that also offer repair services?
