Robbin
and I find a really nasty crack at the joint of the aft dinette seat and the inside floor of the hold. While I am down there I then notice another small crack on the outside of the hold where the dinette floor rounds up to the wall/front of the seat. These look suspiciously related.I then quickly exited the boat (I have it in my back yard currently) and inspect the underside. I see no damage what so ever. So I then assume the Cat 22 is double hulled. My question is this. How do I repair this nasty crack?Then while I have my head in the hold inspecting the crack I notice what looks like a bulge in the keel trunk back by the battery tray, but almost below the electrical panal. I need to get a mirror and inspect it more closely, but it looks like daylight reflected off my finger. Yet this hole/bulge almost appears to be made that way as there are no jagged edges and it appears to be formed as opposed to having pulled away or punctured from the outside as there are no cracks around it.I also see there are cracks around my keel lock down bolt and a rust trail running down into the hold as if it leaks some.As you can tell, yesterday was spent looking much like an osterich with its head in the sand. I finally had to call it quits when all the blood ran to my head and I got dizzy!
Any adviced or suggestions would be very welcome.Thanks!Robbin
