snatch blocks
Tony M.
What differs a turning block from other blocks? I have ESP Blocks by Harken for my jib sheets(furling). They are fixed to the toe rail aft of the winches. Would I use a snatch block in conjuntion with the ESP Blocks for sheet (fairleads) adjustment? thank you Tony
Jun 21, 2004
129
- - Westbrook, CT
Not as strong?
I always thought that snatch blocks weren't considered strong enough to function long term as turning blocks. And why would you want to do that (use a snatch block permanently as a turning block)? Snatch blocks are expensive, turning blocks are cheap(er). But for a quick re-rig, or as a moveable fairlead, why not?
