Snap shackle on furling jib halyard?
916
Hunter 37C Seattle
I was helping a dockmate hoist his furling jib for the first time ( new boat to him). The halyard terminated in a snap shackle which attached to a conventional horse shoe or "U" shackle that attached to the furling head. He said he was gong to leave the sail up for a few months and did not have another jib, so wouldn't be doing sail changes when underway. I told him to wire the "U" shackle so the bolt wouln't back out and said to check out what other people do for the shackle at the end of the halyard. I use a locking shackle on my halyard since it sits hoisted for months and is rarely checked. So snap shackle OK, or locking shackle the better practice?
Snap shackles are a disaster just waiting to
happen. Locking or screwed D shackles for that application are a lot better.
Bob
snap shackle
You can use the snap shackle. However, to avoid it opening at the worst time, you should use a plastic wire tie to hold it shut. When you want to take the sail down, just clip the wire tie.
Jun 19, 2004
512
Catalina 387 Hull # 24 Port Charlotte, Florida
I always use
stainless steel wire as a backup to ensure that I won't have the pin backing out due to vibration. My halyards are equiped with snap shackels with the wire to ensure I don't have the problem of it opening up if I don't want it to. I also use it on the shackel on my anchor rode to ensure that I don't loose the anchor.
Ray T
Jan 24, 2008
224
Hunter 216 West End - Seven Lakes
snap shackel
Be wary of plastic ties they will degrade from U V rays. the black ties seem to last longer than the white ones. Your best and cheapest bet is the U shaped shackel with a screw in pin secured with stainles wire.
Ross
Jun 15, 2004
14,693
Snap shackles are a convenient, quick way to detach
a line from a load. Carabiners are much better if you must make rapid changes but screw pin shackles are the most secure.
