Hmmm...
My first thought was: Won't the headsail and its halyard hold the sail in place, and support the mast, even if the forestay parts? You could argue that the foresail luff may fail when the load is transferred to it, but the luff is a very strong component, and does offer substantial redundancy. Some careful thinking reminded my that our furler is set up so that the tack of the sail puts a strain on the bow through substantial furler hardware, which is not dependent on the forestay. So I doubt that the forestay would drag the foresail overboard. Any actual data on this likelihood?In any case, we would:- Immediately head downwind.- Secure the spinnaker halyard to the bow cleat, and take a maximum strain on it. (Lacking a spinnaker halyard, we would drop the main, and use the main halyard, extended by the docklines on the bow.)- Clear the wreckage. We carry wire cutters to sever the shrouds if needed. We will bring aboard what we can (especially the sail) but the emphasis will be on safety of the crew and of the vessel. This will involve some serious good seamanship, since we will need to minimize our speed through the water while maintaining some control. Dropping the main, and steering on the hull will probably get us started. Our boathook is long enough to allow us to push flotsam down below the keel if that is needed. Recover the foresail halyard if possible during this process since that will allow us to either increase rig stability, or set a second foresail as needed.- Reset the remaining sail(s), and head for home.DavidLady Lillie
