Hi,
I just removed the painted on name from my '84 Catalina 27. It was on both sides, near the stern. Getting the paint off was easy - I used Easy Off oven cleaner and it is down to gelcoat. However, where the letters used to be the gelcoat is proud of the surrounding area by up to 0.01". I can only assume that the paint was protecting the gelcoat behind it from 30 years of buffing and polishing, and hence the gelcoat behind the letters never wore down.
The only solution I can think of is to carefully block wet sand with 600 grit by hand to even out the surface. A little color ghost is not an issue as I'll place the new Vinyl name over the same area, but if I don't do something the old letter shapes will show through. I'm nervous of the unintended sanding the area around the letters will get, and the potential to wear through the gelcoat.
Are there any better solutions I might try ?
I do have both line and DA air sanders in the garage which would be easier/quicker, but I suspect they would be more likely to remove material from the wrong places.
Thanks,
Andrew
Thanks,
Andrew
