Smelly water ballast..
C
Cap'n Jon
I just posted a question to the Headmistress (shades of my English schoolboy upbringing - aarrrgghhh!)Please go there and read _"I smell a herring, I think... Thanks. Cap'n Jon
Rick webb
Flush it out
Two things will prevent the smell bleach and using fresh water. If they have access to a hose they may try to open the valve and run fresh water into the tank from the vent next to the valve. The male end of the hose just fits inside the opening. Not sure how long it would need to run to change out the water 100%, a while I reckon. Then add bleach I use about two cups each time on mine, I am afraid of what it may do to things I cannot see inside the ballast tank. If that does not work pull the boat out, open the valve flush out the dirty water with fresh water the launch and fill with fresh water again. The water out here in Mississippi is the most dirty I have ever sailed in and mine still smells fresh.
Joe Youngblood
Smelly Water Ballast
I had the same problem on a Hunter 19 after I left the boat in the water for about 2 mons. The remedy for us was to add 1 teaspoon of bleach per 5 gals. of water in the ballast tank. (this came out on our boat to about 1/3 cup of bleach) No more smelly ballast!
