It doesn't matter what the tank is made of, the smartest thing you can do is replace it....'cuz if the tank is metal, JBWeld has sealed the leaking fitting, but the first leak in ANY metal tank is only the FIRST leak...urine is turning it into a a colander. If it's polyethylene, it hasn't permeated, but nothing bonds permanently to PE, so there's an excellent chance that the fitting you "welded" is already leaking again...if not, it will. Tank mfrs use a process called spinwelding that was melts the edges of the fitting and the edges of the hole to cause them to blend into a continuous mass....so what you called "putty" is actually melted PE. The odor on your hands is residual odor from stinky hoses and the leaking fitting that has tranferred itself onto the outside of the tank...and most likely every other surface in that area and any area the hoses passed through.
Ronco Plastics (no relation to the VegoMatic Ronco)
Ronco Plastics Marine Catalog is your best source for a new tank. They makes TOP quality thick-walled water and waste tanks for a very reasonable price and has more than 400 shapes and sizes, over 100 of which are non-rectangular (which means you might be able to fit a larger one in the same space), and they install fittings in the sizes and locations specified by the customer when they make the tank.
As for how to get rid of the residual odor...there's a product called PureAyre
PureAyre that will eliminate ANY odor, once the source of that odor has been eliminated...it's safe to handle and is even rated for use around food. Amazon has it...check it out.
