Hi Wilhelm,
My Moore knot meter went south a few years ago. The needle got warped from exposure to the sun. I bought a new one from Defender a couple of years ago, and, after fixing it to the bulkhead, I couldn't get the contact screw to unscrew, and couldn't get the electrical lead to attach to it. I've never got around to sending the unit back to Defender for an exchange. Just went sailing instead.
When I bring the boat up to Seattle I'll be keeping her on the hard for a few months to paint the hull and deck, and do a few improvements in the cabin. I'll replace the knot meter. I'm also going to install my fixed GPS system and tillerpilot that I've had stowed away for the last two years, along with a CD stereo system.
As for enginge maintenance, some of it I do myself, like changing filters and oil. When I haul out the boat, I have a mechanic come in and check the alignment, and do the other service stuff according to the manual. I usually check the cutlass bearing at this time to. If the shaft is wobbling, I have it replaced. I always buy two bearings, just in case I can't get one or if it takes to long to order one. This way I can get the boat back in the water so I'm not hanging around waiting to go sailing.
I love this boat. Everytime I think about "upgrading" to a larger boat, I have a hard time executing a plan to actually buy one. It comes down to this: a) the Vega is solid, if it ain't broke, don't fix it; b) will go anywhere a big boat will go; c) is easy to sail, especially single-handed; d) maintenance is pretty much hassle free (a big consideration, especially when thinking about "upgrading" to a larger boat, keep all systems simple (KASS a spin off of the old KISS acronym); e) mine's paid for, and doesn't cost an arm and a leg to birth. The Vega is simply a pleasure to sail. I miss sailing mine, and can't wait to get her up here from the Bay Area. Once I get her to Seattle, I want to do a few things to her before I put her back in the water, things I've put off far too long, like finally getting her topsides and deck painted--flag blue hull with blue-glo white deck. She'll be a sweet little thing on the Puget Sound. Yeah!
Cheers,
Steve
WL wxt8981@... wrote:
Hi Steve;
I guess the main thing is you're happy with your Yanmar. I
am! Running your engine at 2800 rpm sounds right (like I
run my engine at 3000 rpm). But without any other data
it's difficult to compare performance. About speed- I have
a GPS that gives me the over-ground speed, and a VDO-Sumlog
that gives me through-the-water speed (hence I know the
speed of a current).
I installed the engine myself, it wasn't too difficult. I
do all the maintenance myself and thus far all I had to, if
you call it 'repair', change the impeller twice. That's
all.
Happy Sailing.... Wilhelm, V-257
