Jeff jones
We have/had a 15 year old AC/DC Norcold 40W refrigeration unit (L-shaped evaporator) which up until this last week has served us well. This Sunday, after a long weekend trip the unit decided to go south, permanently (compressor motor groan, high heat, tripped breaker). At least it waited until we were back at the dock ready to load up and go home! We have an 8 cubic foot top loading box, moderate (4" nominal?) insulation, and an adequate (1" wide) seal on the lid. The 'old' unit (installed by the original owner) was supposed to cool a box of 6 cubic feet, but managed to keep our 8 cubic unit at 38-40F at a cost of 68 -72Ahrs per day at 85F ambient. Run current was 5.7A (thanks, Link 2000R).The question is… Should we go with the small evaporator ColdMachine, which from specs seems to require 5A run current or the larger unit, which requires 5.5A? I would assume that the smaller unit would work out fine, but would hate to have regrets after the fact! With the small amount of $ between the two units, I am considering the larger model with the assumption that run time will be reduced and overall efficiency will be quite similar. It is very important to me to improve, or at the very minimum, maintain our current Ahr consumption. Am I missing something? We leave the refrigeration running continuously during the 6 months the boat is in the water. I guess I will have to buy a small 12V supply or charger to run the unit on shorepower (house bank is disconnected when we leave the boat to protect against a power failure leading to possible discharge of bank). I plan on connecting the supply's output to one side of a DPDT relay which is energized by 110VAC so that it is 'out of the loop' when I'm charging the main bank with my 3-stage 100A charger and is similarly disconnected from the 12V system when shore power is not available and the main bank and/or alternator is supplying power to the refr. Is there a unit you recommend? With start-up surge taken into account, what size supply should I require?One additional item. I installed a 'mixer' fan in the box shortly after we purchased the boat to better distribute the air within. I have the fan wired to a switch which energizes it on when the lid is closed (didn't want it to blow cold air out when the top was open). Takes 0.1A to run and seemed to accomplish the task of keeping food evenly cool throughout the box and reduce Ahr consumption over-all. Any thoughts on this technique?I look forward to your reply!Jeff JonesEscapade
