higgs - he has BB size blisters
they are in the gelcoat. The important thing we need to know is if the boat is bottom painted. If it is than he has to remove the bottom paint and the blister should dy out without popping them. I would agree with you is there is no bottom paint. The algae and slim could also be trapping the water in the gelcoat. Higgs, SHADS states, "notice small blisters all under the water line. They are the size of a ball point pen tip". I have had these type of blister before and they are nothing you worry about. Your method of repair is not called for unless the blisster are dime size. SHADS, if you not sure post some pic(s) of the Catalina 22 web site. I think you should join and talk with other owner. I think you'll find out the boat is fine. The only reason I recommend a barrier coat if the boat is not painted is becuase it is a hell of a lot easier now, before the bottom oaint goes on. A barrier coat would protect the boat from any future problems.
