Mixing elbow
Yanmars typically coke up after five years, allowing the engine to start briefly before dying. In any event, keep the raw water intake lever closed until you get full running from the engine. Otherwise you could flood the muffler, and the backflow could get in the cylinders. Very too bad. Replacing the mixing elbow is made easier by disconnecting the four bolts at the exhaust manifold. You'll need a new manifold gasket as well as new mixing elbow. $150 I think.
