Over the last three months I've noticed that my tiller was starting to feel sloppy. I removed the tiller and found that the horizontal bolt on which it pivots (so you can tilt it out of the way at anchor) had worn a larger hole in the tiller stock. I came up with a couple of possible fixes:a) fill the hole with epoxy and drill it out afterwards to the right sizeb) widen the stock aft to make a tighter fit in the tiller housingc) get a new tillerAny other suggestions? Thanks in advance.PeterH23 "Raven"
