Boat came out of the water for the winter and I figured that I'd get to work fixing the sloppy tiller. Pulled the rudder out and found it was water-logged. So, the rudder was drilled full of holes along all of the crack lines. Dried out and then faired and glassed back over. When this repair work is done the rudder bearings will be built back up using epoxie with graphite filler as per the West System "Fiberglass Boat Repair Manual." I am putting photos here as this job progresses for anyone who is interested.
http://s266.photobucket.com/albums/ii258/greasy_snipe/Ranger 26/Rudder Job/
B Good
B Good
