Slight rudder shudder at higher speeds, cause for concern?
caguy
Sep 22, 2006
4,004
It isn't much but it is noticeable at speeds of about 5+ kts. I can't see it but I can feel it in the tiller with my hand.
Has anyone else experienced the same, is it normal? If not what is the fix?
Nov 16, 2010
81
Catalina 22 Mactaquac Headpond
Re: Slight rudder shudder at higher speeds, cause for concer
Sometimes stuff can get a little worn but I find that slight back and forth ossilation is usaully caused by a dirty or ragged underside. Whether a badly pitted keel or a barnacle covered bottom the disturbed water flow makes eddies that can wiggle the rudder. Nothing nasty as long as your hardwares solid.
Dec 1, 2010
69
Catalina 1978 C-27 Nortons Marina
Yes, I too have felt the same thing. My hull has very little pitting and rudder is very smooth. It feels normal and there is nothing that I feel is shaking apart. I on the other hand have only one season under my belt, for what its worth.
Dec 16, 2006
353
Hunter 25.5 Cayuga Lake, NY
My Mac22 did the same due to water flow over the swing keel lift cable which is absolutely normal. Also, I do get the same minute vibrations felt thru the tiller on our H240 hunter at sailing speeds over 4 knots. I use it as an indicator that I'm having a good sailing day and enjoy the ride.
hewebb
Oct 8, 2011
329
Catalina Catalina 25 Joe Pool Lake
My 25 does that and I put the transmission in gear and it stops. I assume that it is the propeller turning. (Inboard Diesel)
Nov 8, 2010
11,386
Or it could be something more complex... vortex shedding. Or a lack of it. As a liquid flows over a foil, when the two flows meet at the trailing edge and flow to the tip they will produce a vortex. You see it on planes wings all the time. Same happens on keels and rudders. On rudders you can often feel this in ranges of speeds.
If your rudder bearing are good, then it is probably not an issue.
Mar 19, 2011
225
Catalina C25 Eagle Mountain Lake
Mine does it. More so under power than under sail.
I need a bottom job and the keel faired. Probably stop it or reduce it so that it's hardly noticeable.
Doesn't bother me.
