Sliding hatch holds water
Mark Major
The lexan sliding hatch over the cabin on my '86H23 has a section of wood across the leading edge, on top. The wood is shaped in such a manner (@1/2" at center, tapered toward edges) as to slightly depress the center of the sliding hatch so that it holds a small amount of water, which seeps and drips into the cabin. Is this design original, and other than caulk, has anyone come up with a fix? Mark Major s/v "Lesismor"
Bill O'Donovan
Common problem
You'd a thunk they'd have fixed this over the years. You can either drill a hole in the wood piece to redirect the flow, or put a bucket inside to catch the most obvious drip. Many of us have this problem, on bigger boats as well.
Sep 25, 1999
601
Hunter 23.5 Indian Lake
leak
During one of those memorial day weekends when it rains constantly , I noticed the same leak, I have just recaulked etc, and with nothing better to do , i caulked the inside bottom of a screw where it was leaking , thinking it was a waste of caulk ,it has held for 3 years, good luck , also make sure to keep the track clean of any debris, good luck , Mike B
Bob Zanowicz
my solution
My boat has 3 x 5 ft of navy sunbrella cover with grommets in each end. I bungee each corner and I have never had a problem with leakage once the cover is on. The former owner came up with this solution and it works for me. Bob
