Doyle swingbatten
Trevor, the sail's fantastic! look in the archives for my post of the old bedsheet on top of the new sail-it puts back the roach-about 30% more sail area, and the sail shape is much better. Doyle built the sail to their improved design, which puts the battens in a sleeve so they move easier and can be easily replaced. after a while, we found that the small mast section on the selden 356 rig sometimes caused the sail to bind. Doyle immediately attacked the problem, reworked the sail several times-they came to the boat, removed the sail and installed my old main each time-and now it works really well. Sail shape, even reefed, is beautiful, and adjustable,and she's much faster-1-2 kts faster in light airs (full main up to 12kt). In additon, better shaping and draft control means less heel, so you can carry more sail for any given wind. the only downside is you have to remember to swing the battens when reefing! in my case (I'm short!)I have to go up the side of the arch to pull the control line-well worth it!
