This is intended for JC-II but please chime in if you have experience with this. John on your fathers design for the 33 the backstay splits and attaches to the hull flange with the u-bolts you described in the other thread, I like this arrangement but I have removed my toerail in favor of a wooden bulwark to be built at a later date, the hull/deck was joined with fiberglass tape and epoxy, I plan on keeping the same backstay arrangement however without the toerail it will need some backing plates. is the 1/4 u bolt you recommended for the 30 alright? is there a certain type of unbolt (hi test) that is needed? and what sort of backing plate is needed? thanks in advance
