skeg rebedding?
dutchy
Mar 7, 2010
28
Hunter 34 Black Creek
I have a little movement in the skeg of my Hunter 34. (the thing that the prop shaft goes through just forward of the prop.) It is minor but the surveyor suggested rebedding it on the next haulout. I did read a post from quite some time ago but can no longer find it. If anyone has done this, I would appreciate any feedback. Thanks.
Sep 30, 2009
14
Hunter 78 h30 Annapolis, MD
Skeg?
I am little confused by your post, the skeg is the part the rudder is attached to and is behind the prop. The cutlass bearing is in front of your prop, is that what you are referring to?
dutchy
Mar 7, 2010
28
I am uncertain what it is called. It is just in front of the prop and I think houses the cutlass bearing.
Jun 4, 2004
834
Hunter 340 Forked River, NJ
Strut
The metal piece that holds the prop shaft is called the strut or prop strut. Check the HOW archives for past advice or call/contact Hunter Marine and ask how the factory beds them.
385
Harpoon 5.2 Honolulu, HI
I hope your'e talking about the cutlass bearing and not the actual strut. I tried to pull my strut to replace the cutlass bearing, but ended up moving the engine instead because the strut wasn't budging.
