Maybe this will help, maybe not
After reading the posts regarding the different pitches and diameters, I must agree with Phil - Ask the experts for a size recommendation.However, for what its worth, I have a 1997 h40.5 with a 50hp Volvo. The original prop was a Martec 18x16 2-blade. I just installed this spring an AutoStream 3-blade feathering prop. This is designed in Australia and marketed in the US by Martec. I bought through pyacht.com. The recommendation was for a 18' diameter with the pitch set to 12" for this 3-blade prop. It was right on the money.At WOT I turn within 25 rpm of the speed with my old 2-blade prop. My top speed has increased by 0.4 kt from 8.1 to 8.5 kt at WOT (3000 rpm). At 2000 rpm I cruise at 6.7 kt.I don't know what engine is in the Passage 42, but I would suspect something around 65-70 hp.BTW, this AutoStream prop has EXTERNAL pitch adjustment screws and can be repitched by a diver without a haul-out. A single grease fitting lubes the prop underwater and the zinc attaches with a single nut. ALL maintenance can be done underwater without a haul-out. The pitch is individually adjustable for forward and reverse as well.All this and $1000 UNDER the MaxProp model without the external pitch adjustments. Did I mention that the construction is all stainless steel? Virtually no electrical difference between the prop and the monel steel shaft. 5 year warrantee.I've got pictures of the installation if anyone is interested.Rich
