size of the ice box of beneteau 352 1994
Sep 4, 2010
51
Beneteau Mooring 352 PUERTO LA CRUZ
Please who can tell me the size of the ice box or freezer inside the galley of the beneteau oceanic/mooring 352 1994 ? I want to change the old refrigeration system came with the boat which it runs with the compressor driven by the boat diesel engine and have a holding plate inside the ice box or freezer . Have two options: installed a Isotherm refrigeration system, water cooler, self pump, which draw between 2.5 , 3.5 or 6 amp. max depending in the model. Also, do you think I can used the old holding plate already installed from the old system or it is better to install a complete system with a flat evaporator, but I need to know the size of the icebox to decide which model in order will work fine and still not to draw to much amp. Also would like to know if anybody had change the refri. system and how came out to be the change... Thanks
