Ask More Questions
Recommend asking him more questions:1. What is the top wind speed you can use his 135 without over stressing the fabric and blowing it out?2. If you got an asymetrical would he still recommend the 135?It depends on how you sail. If you're a light air sailor and the wind pipes up to 15 or 18 knots and you head for the marina then maybe the 135 would be a good choice. When the wind lightens up and the boat slows down do you crank up the engine? If so, then again the 135 might be a good option.If you might get an asymetrical someday, which I'd recommend if you and your crew can handle it, and you want to sail more than motor, and you don't run for cover when the wind pipes up when there are a few white caps, then I'd think the 110 would be a good choice. Which ever sail you choose as him how close is it to the next heavier weight cloth. If you plan to keep the boat a while and don't want it to get blown out as quick then consider the heavier cloth weight. On the other hand, if you race and do sail changes and don't push it then you'd want to use the lighter weight for performance and easier handling.
