I have a 2002 Hunter 340 my original batteries have been changed out to optima's my boat yard doesn't like these.. I had purchased these in the last 8 months now have starting problems. I am going to replace them with Deko as to boatyard recommendations. My question is what were the original size of batteries. I will bump up a size but want to pair the charger with batteries. Because of all the upgrades on boat and I have read that the optima's can be problematic if the charger throws too much power to them.
Your boat yard is feeding you a line of BS, or they really are that
ignorant.......
Your starting problems are most likely:
*You are under charging the batteries
*You have wiring issues
An Optima should EASILY start your motor. This is what Optima Batteries do best.
#1 The original banks size means nothing. Your bank should be sized for
your use. Nearly every boat builder out there throws horribly undersized banks into boats in order to save money.
#2 Optima's are good quality batteries, though not as good as they used to be now that EnerSys sold the brand off to Johnson Controls (JCI). That said orbital/spiral batteries pack less Ah capacity per sq in of foot-print that flat plate batteries do. This is why they don't make great house bank batteries and you need more of them to do what you need.. For example an Optima Blue Top Group 31 is a 75Ah battery but a Lifeline GPL-31XT comes in at 125Ah in the same BCI case group size. That is 50 more Ah's in the same exact foot print! Optima batteries csot more per Ah than other AGM's.
Optima Blue Top Group 31 AGM = $3.98 Per Ah
Lifeline GPL-31XT AGM = $2.90 Per Ah
The Lifeline is also a premium quality AGM...
#3 I understand the yard sells Deka. If you are sticking with AGM Lifeline and Odyssey are the two premium AGM brands.
You may want to read this before making any decisions:
AGM Batteries - Making The Choice
#4 The size of your existing charger should not dictate what size bank you have but if you are sticking with AGM batteries then you really need a charger designed for AGM's. AGM batteries
should have temp compensated charging.
#5 You will not "overcharge" your batteries unless the voltage settings are incorrect. The current flowing into the battery is determined by the battery, not the charger. Voltage is what kills VRLA batteries (valve regulated lead acid batteries) not current.
When you read that above link be sure to read the manufacturers cycle life data for Deka AGM's...
