Stainless is just as vulnerable to urine as aluminum...it just takes a little longer. So you will have to replace it... the only question is whether it should be done now or can you wait. Do you know how old it is...when it was installed?Our holding tank is stainless steel not aluminum and it is 30 gal.
Replace 'em. For only a little more than the price of a Jabsco, you can upgrade to PHC "conversions"...check that out here: sbo.com PHII PHC LBAOur two Jabsco manual toilets do not work well (according to the survey) and are positioned more than 6 feet apart.
You wouldn't be able to use in the Great Lakes or Lake Champlain...they're all "no discharge"...holding tanks only. So while you'd be able to use it almost everywhere else, I don't think it's the best choice for you at this time. However, you did say "Great Lakes AREA"...and you would be able to use in the rivers...so let's not rule out an Electro Scan or PuraSan yet.Next April we plan to start the great loop from Naples, FL and to do it over 3 years or so. Most of the time will be in the Great Lakes area.
1. Does an ElectraScan make sense in our situation?
That sounds like a good plan.If yes, what is the recommended configuation. One recommendation we had was to hook the ElectraScan to the aft head, and to hook the forward head to the holding tank.
Yes, you would. But that's not the worst thing that can happen to you.If we are in NDZ for lengthy periods, we would then be liimited to using one toilet?
Yep...when installed correctly, the Electro Scan and PuraSan work just fine with ANY toilet. Wiring is the critical issue.3. Do manual toilets work well with ElectraScan?
