Peggy
Want to verify something...If I read correctly, in your book you state the need for a siphon loop between the toilet hand pump and the bowl inlet. I have a sailboat and a PHII toilet without this loop. That 3/4" line is currently about one foot long.
I do have a loop between the Y-valve and the thru-hull discharge. The run between the Y-valve and the holding tank goes up as high as the siphon loop on it's run to the holding tank but without the siphon breaker...no choice there on the run to the tank.
Ed
Ed
