A
Adam Kerner
I've recently replaced my head and all plumbing. I'm using a PH II, and all Sealand hoses. All seems working fine, except for the following: I've naturally installed anti siphon loops for both the intake and discharge hoses. The previous head was electric, and the intake loop had an electric vent on the loop. I changed this to a "manual" valve on the vent opening at the apex of the loop. When I pump the head, it sucks air into the line, so little flushing water enters the head. If I remove the oneway valve, and put my finger over the opening while flushing, it works great.I've now tried 2 different valves, w/ same result. Any ideas on how to keep proper suction in the line so that I can pump just water, while allowing air to enter when needed to break a siphon?Thanks,Adam
