Siphon break
The siphon break is installed by the boat builder and is not part of the engine. Noting that your post is relative to a 30 and the M25 engine, I assume it is in a Catalina. If so, the siphon break is under the galley sink where two hoses make a U turn.Catalina usually put a length of hose over the top of the siphon break to assure that any water that came out would go to the bilge and not into your SOS pad under the sink. The hose tends to accumulate stuff that makes the siphon break valve sticky. Sometimes it can be cleaned with the proper results. Otherwise it can be replaced with a newer type that contains a miniature joker valve that works well and doesnt put out that annoying water drip. Forespar 903001 is a good one.
