L
lee
recently obtained a 22 catalina(70 ish model) the problem i have at the moment is that the bottom hasnt been cleaned in 2 years and sitting on sarasota bay, full now with barnicles. my through hull fitting that drains the cock pit via two drains, that i assume is encased on bottom at the through hull with barnicles. the cock pit is filling up and spilling over into the boat, and with the several inches weve had(already bailed it out tonight,) it could sink in all this rain before i can get a battery and bilge pump installed etc. my question is, can i run a coat hanger, etc through the thru hull fitting to tru and unclog, or should i maybe drill hole into the side above the water line and install a new through hull fittingto drain the cock pit. Also catalina owners, this clogged through hull sits right next to cable raising/lowering the keel. how can water drain by gravity feed if the through hull is below the water line? i assume that it is any way.thankslee
