sink thru hull
David Jones
I have a 72 22' oday . There is a thru hull connected to a sink. I doubt I will ever use this. What would be the best way to close this up? Thanks.
Justin - O'day Owners' Web
Through hull
David - If you're serious that you'll never use it, I'd glass over it the next time the boat is out of the water. If you ever want it back its easily accomplished with a small hole saw. If you're less sure, I'd remove the seacock and thread a pipe cap onto it. Justin - O'day Owners' Web
