sink exhaust hose advice
May 20, 2020
23
Hunter 30 Nelson BC
This one should be easy but living rurally with no suppliers locally finding sourcing the right part a bit of a challenge.
I need to replace the exhaust hose for our kitchen sinks on our '91 30T. I can't find the original hoses anywhere (short 2-3' sections with rubber ends to clamp on the pipe fittings). Would like advice on which of these, or anything better, anyone would recommend:
https://canadianmarineparts.com/product/hose-gen-pur-8/
https://canadianmarineparts.com/.../corrugated-silicone.../
https://canadianmarineparts.com/product/hose-blu-sil/
Hose (I think) was 1 3/8 inside diameter.
Jan 4, 2006
7,470
Are you talking DRAIN hose for your sink or exhaust hose for your engine ?
I get the impression from the word sink, it's a sink drain hose you're looking for. The ones you show are $$$ high temp. specialty hoses.
I can imagine there aren't too, too many marine stores in Nelson but it is one of the most beautiful areas of B.C. Maybe look in Amazon.ca for drain hoses or for that matter, any other Canadian marine store for drain hose.
766
Hunter 260 winnipeg, Manitoba
Assuming you are talking drain hose - are the thruhulls above or below the waterline? If above the waterline you could also check out what might be available at your nearest big box store or Canadian tire. Below waterline I would look at some of the offerings mentioned in earlier responses.
Jul 18, 2015
74
South P10 Pugetopolis
Too bad the border is closed... Fisheries used to fly parts up, even to Desolation sound. This type of hose has other applications, we used this same hose for suction hose on wildland fire fighting pumps.
You might try one of the safety industrial houses in Neslon that supply fire equipment or irrigation equipment to source the hose.
