Sink Drain To Head Intake
559
Irwin Barefoot 37 CC Sloop Port Orchard WA
I have been thinking seriously of hooking my sink drain to my head intake as suggested in this forum. I have a 1 & 1/4" sink drain hose and a 3/4" head intake hose. I would suspect that reducing the 1 & 1/4" hose to 3/4" and connecting that to a three way 3/4" hose barb tee would be the easiest installation, but I'm curious about the factory installations. Do they use a 1 1/4" thru hull with a 1 & 1/4" tee and a reducer to 3/4" for the head intake? Obviously I am a little concerned about reducing the size my sink drain. Any info? Thanks Joe S
Our sink drains and head intake are
both 3/4 inch, with the same size thru hulls. I would think you could get a 1 1/4 x 1 1/4 x 3/4 T and make that work without reudcing your sink output line size.
Feb 4, 2005
524
Catalina C-30 Mattituck, NY
Both 3/4
My sink and head intake are both 3/4 as well - I don't foresee any issues around the smaller drain line. Best upgrade I ever did! Keeps the head odor down significantly. Rob
Dec 2, 1997
9,011
- - LIttle Rock
Standard sink drain size is 3/4"...which makes me wonder
Are you measuring the outer diameter of your sink drain hoses instead of the inner diameter? Hose sizes are always determined by the INNER diameter because outer diameters can vary 1/2" or even more due to difference in hose wall thicknesses. If the drain really is 1.25 ID, a tee as Stu described would solve the problem.
Jun 13, 2005
559
I have 2 heads and a galley sink and the drains are all 1&1/4"
They come directly off the sink drain fitting which is that size. I think that 3/4" hose for a gravity drain is pretty minimal, but if it works i'l try reducing mine down to that and use a 3/4"tee. Bronze Tee's are available in 3/4x3/4x3/4" and !&1/4x1&1/4x1&1/4" only. No mixed sizes. I might be able to get a mixed size in brass from somewhere but I won't do that. Thanks for the info Joe S
Dec 2, 1997
9,011
- - LIttle Rock
You don't need bronze...
PVC will work just fine for this application. In fact, if you drains were the standard 3/4", you could even use a plastic garden hose wye 'cuz it's not a connection that can ever put the boat at risk if it fails.
Jun 13, 2005
559
Peggie, thanks for the suggestion, I can make it work with PVC fittings.
I can get reducers from 1 & 1/4" to 1" and from 1" to 3/4" and use a PVC 3/4" three way tee. I wouldn't use the home hose fittings though because the tee will be under my sinks, near the thru hull and ball valve, which happens to be below the water line. So it would put the boat at risk should it fail. Thanks for the suggestion though and I will use the PVC. Joe S
May 11, 2005
3,431
Seidelman S37 Slidell, La.
If it was me
I would use a 1 and 1/4 tee, then reduce. The other way you have 1 1/4 going to 3/4 and then back to 1 1/4. Probably won't make a bunch of difference either way, but I would reduce it after the tee.
W
Walt Bilofsky
Plumbing and Vacuum Issues
I'm thinking about doing this too, but have some questions. Since I don't always have the thru-hull valve open when at the dock, I'd rather use a Y valve to divert the sink drain either overboard or into the head intake line. It would be a lot more convenient to connect this under the sink, rather than run another hose down to the seacock. Then to close up the system I would (a) switch the Y valve to the intake line, (b) run water into the drain (presumably pushing the sea water in the line out the seacock), (c) close the seacock, (d) run more water and flush the head out, and (e) put the Y valve back to normal. Does this sound like it would work? Now another complication. The intake line and head are all below waterline. There isn't a vented loop in the line, but I feel like I should install one. The instructions for my electric head recommend installing a solenoid valve on the vented loop to prevent air messing up the pumping action. Since the sink drain won't normally be connected to the head, it shouldn't be a source of air. But if I run sink water into the head intake line, won't it run out the vented loop, which will be lower than the sink drain? Thanks for any help. - Walt Bilofsky
