Single Line Reefing - reducing drag when hoisting Main Sail
Nov 28, 2009
495
Catalina 30 St. Croix
My Catalina 30 has a new loose footed main and a double exit box in the back of the boom. The reefing line is tied to boom with a bowline, then through the sail and down to the sheave at tge back. Then internal to a sheave under the boom up front, down to a standing block at the base of the mast, to an organizer and back to a clutch. I am 76 years old and only one more or less good arm. I have no problems with this set up. The luff stays reefed using the cunningham.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
The main on my boat has blocks stitched in at the tack and clew positions at both reef points. The reef lines run to turning blocks at the mast base and back to the cockpit. The original reef lines are 3/8" but could easily be smaller diameter. As long as they are slack when hoisting the sail, It goes up smoothly. There is probably more friction from the sail slugs in the mast track than from the reef lines. Some MacLube on the slugs from time to time remedies that to a point.
Feb 10, 2004
4,248
Hunter 40.5 Warwick, RI
Thanks all for the replies and suggestions. It seems the consensus is to leave the line loose just stuff it in with the sail when it is doused. That's no problem and I can certainly do that. I may try a cheek block at the aft end but that can wait.
Dan-
See my post (#17 in this thread) for what I used:
http://forums.sailboatowners.com/index.php?threads/mainsail-reefing-concept.109468/
I also changed my OEM reefing lines to some high-strength-techy lines about 5/16".
Feb 10, 2004
4,248
I machined the white fitting myself. I have one set if you would like it. The other set broke somehow. Not a good testimonial, but you can have the one set if you wish. You could try it and if you are satisfied then you could get something similar for the other reef.
Oct 26, 2010
2,229
Hunter 40.5 Beaufort, SC
Rich, thanks so much. I'd love to have it to give it a try. I'll pm you with my address in case you have lost it.
Dan
