Alan, take another look
I agree that the reefing lines are shown, but the internal block system is for the outhaul. If it were for the reefing, then you would need to pull a lot more on the reefing line and each foot of reefing line pull would result in much less reefing line being taken up at the clew. This is not the case.Also, there would have to be two block systems in the boom and there is not room for that.OTOH, pulling on the outhaul clearly indicates that the block system is used. This allows you to pull the foot very tight.If your rigging is not like I have described, then you have something quite different than my Z-Spar rig.I think the drawing is a bit misleading. Does your outhaul line route to the cockpit? Mine terminates on the boom. Also at the bottom of the drawing are variations of the outhaul connection to the sail which leads me to think that this drawing pertains to the outhaul and not the reefing lines. I think the reefing lines are only shown for perspective.
