Solo 356
Seems like we went through something similar to this several weeks ago. I would not want to try to dock our 356 under sail alone, although I'm pretty sure I could do it if necessary, it just would not be pretty. Picking up a mooring might be easier.Regarding sailing in other situations, I'm not sure what the real problem is and I disagree with your assertion that it can't be under sail while alone. I've not sailed very many boats where the helmsman has immediate and unrestricted access to all lines while standing behind the wheel. I find that particularly true in the larger boats I've sailed. If you are going to single hand, then you have to figure out ways to stabilize and get around (sometimes fast). Try standing in front of the wheel.I can single hand our 356 on San Francisco bay without any real trouble (small craft warnings are pretty much issued daily in the summer). Using an autopilot makes it a little easier. Downwind with 25-30 knots behind, I would prefer not to try gybing alone. I've said it before, I'd probably tack around the long way in that situation just to be safe, but I could do it.You mentioned going over crew. I can generally teach a competent 12 year old to hold enough of a course to get the sails up or down. A little more practice and they can usually handle a tack from the helm. Use the crew.I think you could run lines back to the spinnaker winches for the jib, but frankly, it does not put them enough closer to matter that much. It is just as easy to lock the wheel and step forward a few steps and move the jib after the tack. Also, there really is not any room for winches and winch handles to turn that far back on the 356, and most rear cockpit Hunters with the arch for that matter. Getting the lines there will add a lot of friction to the system. I like the arch as it keeps things up out of the way. It also allows the main sheet attachment to be well back on the boom, which makes handling that line a lot easier, not to mention a traveller that is about as long as you can get. There have been many posts on here wanting to know how to set up that system on the older boats.I'm curious if you demo sailed a 356 before your purchase? I can't imagine that the placement of the running rigging did not elevate as an issue (if it was one) prior to purchase. I find the boat easier to single hand than our 290. It is more stable, running rigging is virtually the same placement, and we did the in-mast furling this time.I'm presuming that you have single handed other similar size boats. If not, take your time and get to know the boat. Try to do your single handed exercises in light wind conditions a few times before you ratchet up the conditions. Take someone along who knows what to do, and practice not using them. Actually, that is good practive just in case you have to single hand back to pluck them out of the water. When my wife and I do MOB drills on the boat, one participant sits quietly...because that is the real issue we would face for 90% of our sailing.If you get where you can do the MOB solo, then sailing in general or picking up a mooring should work. Still might have to start that diesel to dock with dignity.Dan Jonas (S/V Feije II)
