Single handing
Tony,Well, I guess my first reaction is that a 356 might not be the boat for you then. There just is not enough room behind the wheel to mount everything you will need to control the boat under sail in the conditions you describe. Even if you manage to get the mainsheet back there, you still have the jib sheets forward.Personally, I do not try to sail the boat into a crowded anchorage or to a mooring and certainly not to the dock. I have a very nice auxillary engine for those activities. I can dock quite nicely solo, anchor solo using the engine. If I needed to sail it into a dock, I suppose I would do so with the jib rolled and the mainsheet in my hand, ready to luff at the appropriate moment. In that event, it would work from its current location.I can't comment on the 2 to 1 purchase issue and if that is sufficent to work by hand. I sail in waters where we regularly see 30 knots of wind. I have seen 44 at one point last summer. I know I can't pull the main in by hand in those winds with the existing system and I'm no lightweight. If you are not concerned about sailing in heavier air, then maybe it is ok with the 2-1 purchase. I'm sure you will let us know how it works out. Regarding the definition of single handed, I suppose that we will just have to disagree. You are suggesting, I guess, that unless one can dock, moor, and navigate a crowded anchorage solo, under sail, then he and the boat do not qualify as single handed. Interesting, I wonder if most would agree?I thought I could leave, sail, get back safely alone (even thought I was doing it)....I guess I'll have to go find a real sailor to teach me how to do it right.And regarding captains position at the helm...again I respectfully disagree. The captain's position on the boat can be dependent upon the activity that is going on. My job as captain is to keep the crew safe first, and the boat second. I will move myself about the boat as necessary to make sure that those responsibilities are best handled. I can think of a recent experience where the crew needed to winch up an all chain anchor in a 30 knot wind. I placed myself at the mast with instructions to the helm and the anchor retreival crew to respond to my commands only. I did this to make sure that there were no hands or fingers at risk during this exercise. I would not have been able to see the activities of the anchor crew from the helm. A common misperception of many is that the captain is the driver....not necessarily so. In fact, I'll turn responsibility over to someone else (with sufficient experience) and take a nap if my rest is critical to the safe completion of the trip. I'm still captain, even when asleep.Dan Jonas (S/V Feije II)
