Rigging Single Handed
Hi there,I actually bought my O'Day Mariner last year and set it up to solo rig - easily. I'm a new sailer, so let's just say it works good for me.I put a bow roller on my stern and center mast trailering supports. This allows me to step the mast alone. Then I used three 2x3's (smaller and lighter than 2x4's) to build an A-frame. The cross leg rests on my tabernacle, the legs, cushioned with rags, sit near the rub rails. The length of the A is from the tabernicle to the bow. Prior to raising the A-frame, I attach the forestay to a clip at the top of the A-frame. I then run a rope to a pully at the bow and raise the A-frame. Then, simply pull the rope. The A-frame transfer the force to the top of the mast, lifting it off the rear support. Once the A-frame reaches the deck, I just remove the forstay and pin it home.Yes, it is that simple. I use thumb screws to hold the frame together, and to break it down for travel. This also works for lowering the mast, just in reverse. The only hard part is centering it on the rear mast support on the way down. I have enough rope to tie it off and move it by hand. I actually designed this after my wife forgot to catch the mast - oops. Just think of the direction of force. The A-frame is the fulcrum.Now, my friend has a 25' Macgregor that he can raise solo. His rig is a pole that mounts to the base of the mast. He uses a 4-to-1 pulley rig to pull it up. He has three side stays per side, I only have two. For me, the A-frame works fine and costs under $20. His rig was over $150.Hope that helps.Sail on,Ted
