I recently acquired a used Simrad WP32. I just got around to installing it and testing it. When I purchased it I assumed it was in working condition. I installed and operated it in accordance with the manual I obtained online. I have not been able to get it to work properly. When tested under motor power, when engaged, it violently swings the heading 10 or 15 degrees to port then back through center to starboard the same amount. It continues to do this multiple times until the alarm signal goes on. Sometimes, after several cycles back and forth, it stays in the turning position and steers the boat in a circle. This behavior leads me to think the Scaling factor is set wrong, but I have checked it and rechecked it and it is set right for my wheel turns lock to lock (little more that 1 turn lock to lock, setting of 2). I have also adjusted the Gain, with no success. I have not run through the internal compass calibration process, could this be causing my problem? I am hoping someone out there has this product and might have some clue as to how to correct this problem. or have I bought a defective unit???
Dean
Dean
