I'm planning to get a used autopilot (most likely a tp10.) I'm looking at its online manual. For power consumption, it says
0.06A (standby)
0.5A (auto)
I guess auto means you're actually running it and it's steering your boat. So if I have a 100 AH battery (from walmart), does that mean I can running it for 100 hrs (I read that you should only draw down 50% of the battery, so 50 AH divided by .5 = 100)
is the above calculation correct? assuming I'm not going to run anything else with the battery.
0.06A (standby)
0.5A (auto)
