One 'No' vote for the Simrad
Vic, I installed a then-Navico WP300CX a/p on our Pearson but, after 2 internal electronic failures, I removed it and have it stuffed under the v-berth as a 'back-up' a/p to a CPT unit, which we subsequently relied on a great deal when cruising the Eastern, Central & Western Caribbean. I had earlier found the plastic molded parts did not fit when trying to mount the Navico unit and went thru 2 iterations of getting replacements (neither successful) until I basically had to manufacture my own fix. In fairness to Navico/Simrad, this was also the point when one was acquiring the other - their 'customer service' style over the phone was wretched, made worse by limited follow-thru.After removal, I had the unit inspected & repaired under warranty (the failure was in the touch buttons on the pad), Simrad made it sound like somehow I was the cause of the failure. It was an altogether disappointing experience.Jack
