I will be doing my first electronics install. I’ve chosen a “simple” project but need some advice free if sarcasm etc..I’ve read and watched what I can from Nigel Calder and I’m installing a device that sends AIS data from my VHF to Navionics app: see image below
Questions:
1. What’s the best way to splice the very fine NMEA 0183 interfacing wires coming from the new device to my VHF?
2. The manual says I can use an inline fuse or a switch for the device. I’d prefer a switch so there’s not constant draw. However, theres no excess ones on my Sea Dog panel. If I don’t exceed the capacity of the switch can I have the new device share the same switch as my VHF for example? Or do I just upgrade the capacity of the switch so they can share it ?
3. If I have to add an additional switch is this just wired inline like a fuse using something such as this image below?
3. Regarding choosing the proper wire size for the load, I will use the ABYC guide from https://boathowto.com/electrics/wire-size-calculators/ . However, I’m not clear on what is meant by “If there is already an existing fuse or circuit breaker for the conductor you are planning to replace, you can enter the amperage of the fuse/circuit breaker in the calculator instead of the amp rating of the consumer.” Does this mean if I’m using a device that draws 8 amp but the switch is rated for 10 then I use 10 in the calculation on the wire ?
4. I’m confused why the wiring diagram shows no path to ground. It just shows the red wire to + and the black to -
Thank you!
PS: On a separate but related question, Calder says every battery should have a primary overcurrent protection at the terminal but I’m not clear what size and what does this look like?
Questions:
Thank you!
