Simple anchor/chain wash down
Jun 14, 2007
180
Hunter 45cc Florida
Looking for an easy solution for a washdown pump. Look at my entry in "owner mods Hunter 45cc" No thru hull necessary. I used the empty circuit for the fwd entertainment center to power the pump and added a SPST on/ off switch inside the anchor well.
Confused. @Slipin Away .
I have tried on this forum but no luck.. Can you provide a direct link? Sound like an interesting modification.
May 20, 2016
3,015
I replumbed by head so sink drain and head Inlet share a thru hull (let’s you flush with fresh water via sink when leaving boat) then used old he’d Inlet for washdown. It is salt water but that’s better than mud.
